REPOST (Tires&Tubes)
Reeperette /
>>Is there a correlation between the lesser rubber on of course the rear tire and flats?<<
Yep.
>>Is there a better inner tube than the one I can purchase at the locat moped shop?<<
Yep - go to Walmart and buy BELL Self-Sealing Tubes, and if you can buy them 1"-2" oversize...which would be 17" or 18" for the Tomos 16" wheels, that gives you a bit more rubber and makes them easier to install, cause you have to stretch the 16"s to get em to fit the Tomos rims.
They're technically bicycle tubes, but they're very tough, and can self-seal anything up to a major gash, and prolly mostly seal even that, I have nothing but praise for em, and I should know.
>>What tire brand should I consider... original or some "motorclycle" that the local shop has offered me?<<
The OEM Tires that come on a Targa, plainly...SUCK!
Doubly so if you live in michigan....those half-slicks are good only for fully-paved, smooth, even surfaces, which you just don't get around here...and they're suicide on snow, mud or grass.
Go buy yourself some Cheng Shin tires, accept no substitute, they're the real-deal.
Try to get the "A" Tread design if you can, but any Cheng Shin tire is pretty damn good.
Your performance in cornering and braking should also improve.
The tires will run you $18-$24 each dependin on where you get them, and the tubes are $6 a pop, so total damage is around $48-$60...which isn't that bad.
I also reccommend a pair of heavy tire spoons, bicycle ones techically might do, but I've had no luck with the, they tend to snap in half while changing Tomos tires.
Most cycle shops will have a pair, figure $10-$15 for a set of two.
Hope alla that helps,
-R
  Need Manual for 2000 Tomos Targa LXTopic by: Dr Alan Lipman Dr Alan Lipman 04/24/02 08:13AM
  Next Best thing.Re: Reeperette Reeperette 04/24/02 10:11AM
  Re: Next Best thing.Re: Dr Alan Lipman Dr Alan Lipman 04/24/02 10:16AM
  Nah, Don't apologise...Re: Reeperette Reeperette 04/24/02 12:15PM
  REPOST (Instructions)Re: Reeperette Reeperette 04/24/02 12:19PM
  REPOST (Spark Plugs)Re: Reeperette Reeperette 04/24/02 12:25PM
  REPOST (Sprocket Change)Re: Reeperette Reeperette 04/24/02 12:51PM
  REPOST (Sprocket Change)Re: Wayne Wayne 04/24/02 02:42PM
  There is.Re: Reeperette Reeperette 04/24/02 10:38PM
  Re: There is (Front Sprocket)Re: Wayne Wayne 04/24/02 10:44PM
  Re: There is (Front Sprocket)Re: don-ohio don-ohio 04/24/02 10:45PM
  Don&amp;Wayne...Re: Reeperette Reeperette 04/24/02 10:53PM
  Re: Don&amp;Wayne...Re: don-ohio don-ohio 04/24/02 10:55PM
  REPOST (Tire Chains)Re: Reeperette Reeperette 04/24/02 01:24PM
  REPOST (Tires&amp;Tubes)Re: Reeperette Reeperette 04/24/02 01:32PM
  Not at Jackson,OH yetRe: don-ohio don-ohio 04/24/02 09:53PM
  Re: Not at Jackson,OH yetRe: Wayne Wayne 04/24/02 10:22PM
  Re: Not at Jackson,OH yetRe: don-ohio don-ohio 04/24/02 10:25PM
  Me, Being a wise ass...Re: Wayne Wayne 04/24/02 10:34PM
  You're incorrigible,Wayne!LOL!!Re: don-ohio don-ohio 04/24/02 10:42PM
  REPOST (initial Faq draft)Re: Reeperette Reeperette 04/24/02 01:55PM
  Re: REPOST (initial Faq draft)Re: alan alan 04/28/02 07:29PM
  Re: REPOST (initial Faq draft)Re: Fred-Indiana Fred-Indiana 08/04/02 07:34PM
  Re: REPOST (initial Faq draft)Re: Reeperette Reeperette 08/05/02 01:35PM
  Re: Need Manual for 2000 Tomos Targa LXRe: me me 04/24/02 12:03PM
  Re: Need Manual for 2000 Tomos Targa LXRe: Wayne Wayne 04/24/02 01:57PM
