Puch no juice
Hi , i was riding around today , running good , For some reason it would not idle , Next i lost the spark. changed plug,none, cleaned the points, none, changed points ,nope. changed coil ,im not getting any juice out of the flywheel, period
[[[What might it be ? thanz Dan
Re: Puch no juice
you did all of that today! damn, you must have a good moped shop close by.
Re: Puch no juice
Ron Brown /
Dan,
Here is my generic checklist, but based on past posts on the puch, check the connections to the horn. The ignition shares a common ground.
Ron
If you have a vom, check the ignition components as follows:
Disconect the wires from the points. One of these wires goes to the magneto ignition power coil. You should read a low resistance to ground on this wire, 1-2 ohms.
Another wire goes to the condensor, read this to ground on RXMAX, that is your highest resistance range, the needle should kick, then settle down to infinity. Reverse the vom leads, same thing should happen.
Another wire goes to the ignition coil primary, this connection is also connected to the kill switch. Disconnect the kill switch wire only from the ignition coil, the wire to the coil should read 1-2 ohms to ground.
From the wire to the kill switch, to ground, you should read infinity with the switch in "run" and 0 ohms with the switch in "stop".
Connect the vom from ground to the wire terminal on the points and make sure they are 0 ohms when closed and infinity when open. This seems dumb, but sometimes points that look clean do not connect.
Re-attach all of the wires to the points. Disconnect the wire from the points at the ignition coil. Measure this with the vom, it should read near 0 ohms. If your meter is sensitive enough, you should see a slight deflection of the pointer as the points open and close.
With the vom still attached and set to about 12v DC range, spin the motor by hand. You should see some deflection of the meter needle.
Pull your plug (spark, that is) and make sure the piston is at or very near the top of it's stroke when the points open.
Re-connect the coil wire. Measure from the plug cap to ground, you should read 5-15k ohms. If this is infinity, unscrew the plug cap from the wire and read through it. This should be 5-15k ohms, if it is open, replace it, if greater than 15k ohms, it may still work, but replace it with a paper clip for test starting then re-install it after you get the ped running.
Read from the end of the plug wire to ground through the coil, you should see 1-5k ohms. If this is infinity, the coil is bad.
Lastly, using the ohmsX1 scale, verify that all of the grounds really are.
None of these tests are guaranteed to indicate a problem, especially where you read coil resistances and they seem ok. Substitution is the best test here.
To test the coil, connect a spark plug from the plug wire to coil ground, connect an ignition condensor (any will do for this test) between the points terminal and coil ground. Connect the negative of a 6V battery to coil ground and touch the points terminal momentarily with the positive lead. This should give you a spark at the plug.
Re: Puch no juice
HO Fred , your way over my head, i don't have a meter, if i did i wouldn't know how to read it. elect is not a strong point over here .
i don't have anything hooked up as far as light kill and etc.only have the wires to get start.
that s not bad enough i go get another Puch and go for a ride with a friend and a mile down the road this one did the same. hows that for shitty luck. Dan
Re: Puch no juice
Doesn't ground the ignition thru the taillight does it?
Re: check for ground
Your kill switch grounds the points. If you have no meter to check for ground, take the wire off the kill switch and see what happwns.
Re: Puch no juice
YOU HAVE TO STROKE IT TO MAKE JUICE CUM OUT!
