Hard wire e50
Hope you guys can help me with this question? I am trying to hard wire my 84
maxi sport. I have seen the diagrams and understand how to, but in all the diagrams they say to use the grey wire from the stator. Mine does not have a grey wire coming from the stator. This is what I have.
Yellow
Blue with Black
Green
Blue
Blue with green
Has anybody seen this pattern before? Please Help.
Thanks, Matt
Re: Hard wire e50
Salsa Salsa /
Everyone has. Search the wiki!
Re: Hard wire e50
Jimbo Grand Daddy /
Looks like someone has upgraded to the 12 volt coil.
Re: Hard wire e50
Can you tell me what wire substitutes the grey? I bought this and the on and off switch didn't work, and the previous owner used the horn button for the kill switch. So i am trying to do away with the switches that don't work.
Re: Hard wire e50
Run the yellow from the stator to the headlight and taillight together. Just twist the wires from both lights together, jam them in the wiring block opposite the yellow, and tighten. Also, take out those two accessory coils and just leave the ignition and lighting. Less crap to deal with.
Re: Hard wire e50
what you mean? I love he accessory coils, puch is the only bike where the lights dont dim when I hit the breaks because of this!
Re: Hard wire e50
Probably Fred /
Hardwiring all to one coil is dumb/wrong and can overload/fry the coil .
Puchs have a coil for headlight, horn and speedo, a coil for the taillight and a coil just for the brakelight so why not use them all
Re: Hard wire e50
i agree with ken. i just follow the hardwire guide in the wiki and all is well i have tail light headlight brakelight and all are so bright. i dont use my horn or a killswitch.
Re: Hard wire e50
Guys I understand how to wire using the wiki hardwire diagram. It still does not answer my original question. The diagram shows the grey wire, and my stator only has this pattern.
Yellow
Green
Blue & Black
Blue
Blue & Green
What wire would I use in place of the grey wire?
Re: Hard wire e50
Isn't grey the ground?
Re: Hard wire e50
Blue-black is the hot, and should run to your external coil. Ground the blue, ground the green, ground the blue and green, and run the yellow for your lights. Done. Fuck the grey wire.
Re: Hard wire e50
Im trying to figure out why my stator does not have the grey wire. The grey wire is for the tail light right?
Re: Hard wire e50
Salsa Salsa /
OMG DUDE!!!!!! you have a later model maxi that has a different stator. see the attached photo for a full diagram!
GREEN BLACK TO COIL. you might be thinking your wire is Blue/green. . . maybe its just old and discolored.
Yelllow to head light.
Green looks like its your "gray" wire.
Re: Hard wire e50
Thanks for the diagram of the later model. Maybe the owner before me changed the wiring, but the color of the wire is blue with green spots up and down the wire. The way this thing was wired to the terminal is totally different from the stock diagrams. I am just gonna start over.
Re: Hard wire e50
Salsa Salsa /
The one I posed is up to 81' so the wiring is closer to yours than an older one. But if you could find a newer manual I bet it would be better
Re: Hard wire e50
I've seen many stators that do not have the grey wire. I think it's just a version that didn't have a dedicated tail light wire. Just split off from the yellow, as people have said.
Re: Hard wire e50
Does anybody have a 84 maxi sport wiring diagram they could post?
I have searched but only found manuals for sale.
Thanks, Matt
Re: Hard wire e50
First, do you have a 4 coil Bosch magneto. Focus on the start of the power sorce(s). What color wire comes off trhe small coil that sits on top of the large coil with the yellow wire on the generator assy??
Re: Hard wire e50
Hey bro, eat one. All of us GB boys have been running one coil lights for years with no problems. More electrics = more problems and headaches when trying to diagnose problems.
Re: Hard wire e50
Salsa Salsa /
Booooya. Say it again Corey!
Re: Hard wire e50
several diagrams i looked at all had the grey feeding the taillight, always on.
guess if you won't pull the flywheel to trace wiring out, you can look see what color is feeding the taillight (not brake) bulb.
that color is your missing grey wire.
Re: Hard wire e50
Got it figured out. Thanks to all the help from you pros. This sight is great.
My rebuild is almost complete. I will post some pics soon.
Thanks, Matt
