where do I find the 23x2 tires and tube for my 1962 Mobymatic Maybylette? Please help me!
tires
RE: tires fo moped peoples
you silly/whie you no go to fo walmart an bye tire fo bisickle it same ting like all moped tires? walmart sell fo 4 dolla! then you haveen monies left ova fo buy small basket an plastik horn.
you're starting to annoy me Mr. Hayusodumb.
Anyway, Buster, head on down to your local bike shop and see if they have tires in that size. if it's specific to mopeds and hard to find give handybikes a call - 614-299-0550. good luck.
I agree with Simon on that fake poster. I hope things change is his lonely isolated life.
Anyway, Buster, sometime back I was looking for similar tires and never found them. Also one thing I learned was that bicycle tires are measured by the outside diameter, and motorcycle (moped) tires use the rim diameter. what I found was that a 26" bicycle tire was too big, and a 24" too small.
The 23" moped rim actually measured 21". There are 21" motorcycle tires out there, but the width was wrong. It truly was a can of worms.
Somewhere back in the older posts someone found a set, but I don't recall where. You could try search feature using 23x2.
Jim
RE: tires
check out <a href="http://www.stevesmoped.com/">http://www.stevesmoped.com/</a> - they seem to advertise that they have lots of moped tires.
RE: tires
YOU CAN RESEARCH THIS A YAHOO.COM AND SEARCH UNDER MOPED TIRES, TIRES UNLIMITED IN OHIO HAS LOADS OF TIRES FOR BIKES,
RE: tires
Can I find a heavy duty tube type tire more than 2ply, size 2.25X16 for a Kenetic Moped? Or is a heavier gauge tire available in a tube less type? Thanks.
A. Poslusny
trail tires
I am trying to make my tomos ttlx a better bike for tral riding. Has anyone seen some knobby tires for tomos bikes? I think the size is 2 1/4- 16.
