tomos targa electrical problem
My 2000 Tomos w/ 70cc upgrade may have an electrical problem.
- It was working fine until one day when I shut off the ignition and it kept running (just for about 6 seconds).
- That same day, whenever I came to a stop it died.
- It runs very well at high speeds and only stalls when the rear wheel slows (near stop).
Question: What's the most common electrical part that fails on these peds? Does this sound like the problem... ie/ it can't generate enough power for the spark plug at low rpms?
- I've check the carb + my compression looks good.
Thanks,
Jonl
Re: tomos targa electrical problem
Ron Brown /
Jon,
I cant help feeling these two problems are related. When your ped continued running after you turned it off, did it make strange noises?
Have you changed the plug?
Ron
- I tried a new plug... and nothing.
- The 'run with ignition switch off' only happened once... no strange sounds
- It still runs great at high speeds... just dies at stoplights
I found the old posting of checking the electrical components.. so I'll try that.
Thanks,
Jon.
Ron Brown /
Jon,
Try your idle adjustment on the carburetor.
Ron
hey if non of the other things were it im not compleatley sure but it may have been the condenser try that they run for about 15.00 ant themopedjunkyard.com
