Stock clutch springs lbs?
Does anyone know how many lbs the a35 stock clutch springs are? This would help me figure out how heavy I want to go with new springs.
Re: Stock clutch springs lbs?
9.5 lbs 1st gear , 15 lbs 2nd gear .... i think ?.......just get the 20 pounders
For both gears?
I believe on the a35 the tension is the same for both, on the a55 I believe the 1st gear clutch has a slightly stronger spring than 2nd.
