...tune up my moped without losing speed nor power and not using special parts(they arent available for my moped)?
Thanks in advance!
Martin
Thanks in advance!
Martin
more air/fuel mixture means more combustion... or power.
try to find carberator parts... most mopeds use a pertty generic carberator.. you can mix and match them most time with little midification...
Clean and lube moving parts (wheel bearings, chain and sprockets). Replace sparkplug and clean out your fuel system. Then clean the carbon out of your rings, piston head, exhaust port and muffler. Make sure your brakes aren
