VESPA CRANK SHIMS DO I NEED THEM
i got a new crank reed case and kit and all the works and i need to know if i need the shims or not stock has them so do i need them
Re: VESPA CRANK SHIMS DO I NEED THEM
i need crank shims my crank will come with some
oooo ok im doin a 19mm phgb thats not goin work lolol
Wanted Dead or Alive /
Im the only one that can run a 19 phbg on a vespa. I have a 75cc BIG DEPPS and malossi cases that are custom only for my setup. You should bore the case intake with a 1/2" drill bit or send them to me and I will do it right. You run the 13.13 in there and I have a special cut that only I know how to do to get the crank inlet timing just right. I use it on my BRIGHT SPECIAL MOTORS.
MaddMatt -Ruffians STL /
-MaddMatt - Wrote:
> Learn how to work on your shit you fuck.
That is keiths new fake profile trying to be me. I'm mattso, he is mattsso.
Hes asking about crank shims! Between bearings and crank lobes. Not an intake shim. Yes to crank shims. The reed case comes with new ones I believe. There.
Yes you need them.
ok thanks
bump
