1980 peugeot moped
i got this 1980 peugeot it was running fine for awhile and
now is not spark at all i check the run switch and is loose
there is any other way to starter with out the run switch
any ideas let me know
Re: 1980 peugeot moped
Salsa Salsa /
I m not sure how your switch is wired. Normally open or normally closed. How many wires go into it? 2? If its just two try connecting them. Than try disconnecting them.
It could also be part of your ignition that is bad.
Disconnect the wires. When switched off it grounds and kills the spark. So on is both wires not attached.
