need advice
John Proznik /
have an e50 motor that is clicking badly at the crank brg area, changed lube and still hear the clicking. Motor is still running but do not want to seize it by using. Meaning a rebuild is needed. I have not done a rebuild before or do I own the specialty tools to start. Where could I send mtr for rebuild?
Re: need advice
Jason Casher /
1977 mopeds dose good work. they did mine.
Re: need advice
My advice is to quit mopeds or rebuild it yourself. It is very easy to do on an e50.
Re: need advice
i Knew this was an e 50 thread! yeah dude take it apart! e50s are the simplest thing ever. u probly just got a bad bushing, or sometimes, they just click and it's ok. just do a good job, use a torque wrench, get alen key hardware, and its good. do it. don't be scaaaaared.
Re: need advice
No special tools needed.
My brother took apart an e50 and put it back together and he had no experience at all with working on anything with a engine.
Re: need advice
If you're scare here are some ideas while taking this apart
1.) Take pictures at every step
2.) Label everything, if you dont think you need to do it anyway
3.) have a large space to lay things out on step by step
4.) Use the fuckin' internet, its what its here for.
5.) Dont be an idiot and loose shit or work in a dark Messy place.
6.) get a friend to help sometimes 2 brains are better than one, plus the more they know the better you'll feel
Re: need advice
What Rambo said. Good steps, you got this John.
Re: need advice
special tools you'll want but could macguyver around
clutch puller (use two 6mm bolts and somehow pull it out)
flywheel puller (tap the fly wheel with a rubber mallet)
puston stop (put rope in the spark plug hole)
snapring pliers
gasket paper
Re: need advice
You might need an impact driver to get the case bolts out. Sometimes those are really torqued down.
Re: need advice
> down.
^truth while you're at it replace those bolts with hex (edited)
Re: need advice
Quit mopeds, seconded.
Re: need advice
Salsa Salsa /
Shits fucking hard. But ill do it for you. If you wanna ship it to minnesota.
Re: need advice
Luke “Funkenet” Hosfield /
It could be the bearing that connects the piston to the crank, I would check that first.
