Advice on copper fuel line...
I have been researching the idea of using a 1/4" copper hardline w/ in-line petcock & filter for my Trac. I've read mixed reviews on the subject so need to know what y'all advise!
Pros:
- looks clean & classy
- easy to hide... No tubes hanging everywhere
- no tubes coming loose
Cons:
- needs regular upkeep... Tarnishes quickly
- vibrations of tank and engine can shake tubing loose
- have to figure out a way to mount to the carb hmm...
What do y'all think?
Re: Advice on copper fuel line...
why not use 1/4" brake line? Or maybe you like the copper look better? They also have black coated brake line.
it'd be really hard not to crease the hose when you route it, and its a lot more expensive than normal fuel line.
I like the old school, classy look of the copper lines. And as far as creasing it I would be using a tubing bender so that shouldnt be an issue.
Jimbo Grand Daddy /
I use soft drawn copper for oil furnaces as well as refrigeration line. Gasoline would not be a problem. However, any kind of fitting, either flare or compression can be quite bulky, making it difficult to bend in such a small distance between petcock and carburetor.
I use 3/16" copper fuel pipes on Solexes all the time...no problems at all. They don't crack like the originals, and don't break like the newer Hungarian pipes.
http://briansolex.free.fr/faqs.html
Well I have about a foot+ between the tank and carb.
Brian Solex ( brianc) — three hours ago
Thanks...ill look into.this option as we'll.
Use a short section of rubber hose where it connects to the petcock and carburetor. You can use cloth covered hose and bailing wire instead of hose clamps for a vintage look. It'll also give you a bit of vibration dampening.
Exactly what I needed to know! Awesome! Thank you!
Also...anyone else ever do this that may have a pic or two???
Hmm saw this on my el camino looked half decent actually. I'll check around and see if i have a picture of where it meet the carb. I believe it was double flared but i really can't remember was a few years back. once again not a barbed fitting. but just from being a plumber, add a little hear and slide it over the petcock barbs. If done right should NEVER come off, to much heat or not enough and you fucked it all up. but this would make it a hard line so vibrations might cause failure.
LAZERSWAG FAGTAG /
are you fucking retarded? vibration will split the line, cause a leak and result in an engine fire within a week.
There's a reason you don't see copper lines used for fuel and brake lines on vehicles.
Quit being such a fucking noob and get a life you stupid buttwad.
ブロック 666 /
I forgot Lazerswag you where never the noob.STFU asshole
Jimbo Grand Daddy /
Look closely. Someone liked Lazerswag so much they made a fake.
ブロック 666 /
Im sick of this fake then the individual needs to fuck off.Did you look at aldydamned) posts?Straight up asshole shits on everything down everyone says.
^yup I'm terrible for the moped community. I have the balls to talk shit with my real profile.
LAZERSWAG FAGTAG /
And then go in for the reach around.
Any takers?
I'm quite popular Jimbrah. Oh see you Friday right gurl? You gotta see my new place it's got a giant garage. Let's get wasted and weld the shit out of some stuff.
Jimbo Grand Daddy /
I think we need another drunken trip to Harbor Frizzle.
LAZERSWAG FAGTAG /
Awesome cant wait! You bring the lube And I'll bring the towel
GET THE FUCK OFF MY THREAD FUCK NUGGETS!
^the only reason this thread is important is because jimbo and I posted in it.
LAZERSWAG FAGTAG /
Yes I am a fuck nugget. But I belong to Jimbo only. You can't have me
