Turn Signal Possibilities?
Anybody ever thought about wiring in turn signals to a bike that didn't have them stock? I've got a magnum MKII and i'll probably never get around to it (they're not required in GA) but I think it would be cool to install turn signals as a convenience. I know it would require maybe another coil, like a treats mystery coil and a flash relat, switches etc. So has somebody planned something like this out, or better yet done it?
Re: Turn Signal Possibilities?
Cosmo nPuch Stillstolen /
It's on the wiki or somewhere around here.
But, stock Puch is only 6 volts with only a smidgen of current
it can be done
good luck
In order to run a flasher relay you need to have them on a separate circuit. It's possible if you don't have an additional circuit to wire them with a chargeable battery bank, but that's more work.
It's pretty easy to do, and blinking lights are always fun to play with.
I did it on a grande. Rewired the headlight as the coil ground with a switch, and uses the headlight coil to run the lights. Not super hard, just use your noggin.
