gas problems
Ive got a gas problem ok today i filled up my tank and left my house with my moped and when i got to friends house nothing wrong on the way over with the engine but when i parked it up on the kickstand and went in came back out and smelled gas badly so i took it off the kickstand and there was a puddle of gas and when i brought it back to my house the same thing except the puddle was huge and it was in my driveway and i watched it drip from the exaust the header is black with smoke and gas i dont know how because its all the way on the engine but im hopeing that there is something that i can do to help this problem becase im not putting it in my shed because the gas smell will never never come out
Re: gas problems
Ron Brown /
Andrew,
You most likely have a bad or sticky float, float needle or needle seat in your carb. You need to take the carb off and clean and check it.
Ron
Re: gas problems
i forgot to mention that my fuel switch dont work the shut off valve but its still never done this before even with no muffler but ill check the carb
Re: gas problems
I think it depends on where your piston ends up stopping . if it stops at the top it cuts off the gas flow, but if it stops at the bottom it opens a path to the exhaust port. Get your tap fixed and stop the gas flow before it gets to the engine. Let's see what Ron has to say. bruce
Re: gas problems
Ron Brown /
Bruce,
The gas actually goes into the crankcase, if there was enough in there to flow out the exhaust, I think you would be in bigger trouble. However, if the cylinder is horizontal, gas could be wicking around the piston.
In any case, a working petcock and float valve is the solution.
Ron
