Re: Replacing 103 seal without disassembly?
Nick G /
Aaron is correct. the teknix case is fine and easy to work with but the bearings are bad. Of all the cases Ive got, the bearings are always clunky. I just FAG bearings, never had an issue with them. Also the case bolts and nuts that come with these cases SUCK! I have stripped at least 5 bolts with only 6 ft/lbs. Put some Grade 8 bolts on it if you go this route.
