Re: Replacing 103 seal without disassembly?
M-Tenn Aaron /
Just so ya know. Those suck ass. The cases are decent but not great, the bearings are shit. I have a teknix case set if you want it. I lost the case bolts though. The cylinder studs would not fit the gila 70 I had either.
I will have a sweet set of welded stock cases matched to the gila 70cc with FAG bearings and seals installed + a malossi 4 petal reed block with 19mm phbg intake set up for sale soon. Just add your crank, kit, & carb to blast.
