when i time a bike with points. . .
Salsa Salsa /
Sometimes I rotate the stator and nothing changes. The timing stays the same. . . . On a cdi it changes
Re: when i time a bike with points. . .
loosen the screw to the points and move it around..there's a peice that you want to sit against the inside of the flywheel..
RUFKM
Salsa Salsa /
DYTM! IDK
Salsa Salsa /
Yeah. I know how points and a stator work. But sometimes when I rotate it, it doesn't effect the timing.
RADIUM CITY JO$HUA /
AFFECT YOU MORON. JEEZ MA IS SO DUM AT SPELLING
Swoopid Woody /
maybe if points are loose they shift to compensate change. i don't know man sounds spooooky
Swoopid Woody /
and who gives a fuck about speling
Salsa Salsa /
i am on a fucking trac phone dummy! you know what T9 is?
Benevolent Aroh /
That happened to me tonight, I had to change the gap to get it to 17. which was a pain
I Cnt evan staynd alll the bat speling nemore... iam dun width mopads!
Did you set your points gap at TDC?
Lukas McWhorter /
Fuck points. That is all.
> T9 is?
WHAT DO FUTURE SEQUELS OF THE TERMINATOR HAVE TO DO WITH YOUR INABILITY TO UNDERSTAND THE ENGLISH LANGUAGE?!?!
Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang /
i h8 timing. really the worst thing about mopeds. gaah.
yea sometimes its like "haha lol no i'm not changing lol"
blerfg
Lukas McWhorter /
> gaah.
> changing lol"
> blerfg
In a fury of great anger I ripped my entire stator out and threw it across the backyard today.
I have CDI kit on order lol
my points are great.
Salsa Salsa /
i am just trying to see if anyone has had this happend.
most of the time, timing goes great, but once in a while, the timing just doesn't change. . .
My batavus with bosch points setup did this to me for a while. I realized later that the flywheel was all messed up. Could have been my fault, not sure actually, but the flywheel had a crack. Like in the keyway, along the length of the keyway. Hope that makes sense. But when I would adjust the timing it was like nothing would happen. I think it was because as the flywheel would spin that crack would open up, and no matter what I did it would stay super advanced.
Salsa Salsa /
hmm, my flywheel seems fine. . . i took off my cdi and went back to points, but i couldn't change the timing on them. it was really odd.
you confirmed this with a timing light?
im a fan of points. also a fan of CDI$
Salsa Salsa /
Yeah with a timing light. I twisted the stator all the way from left to right and right to left. And the timing did not change 1 degree
Overpriced Parts /
Cam on points worn, metal spring on points bad, pivot on points bad, huge gap, wrong flywheel, worn flywheel , stator moving
Salsa Salsa /
Cam is fine. right and unword flywheel, stator is not moving, gap is good. Ill double check the pivot and metal spring on the points.
I saw it, its true. He went from full retard to full advance and the timing didn't change from 19mm BTDC. The timing did seem to be really jumpy too. Really weird but I can't say it hasn't also happen to me before as well. Its really strange because it you physically move the stator plate, you are moving when the points open on the cam no buts about it, there should be no possible way the timing shouldn't change.
Are you sure you had the arrow pointing the right way on the sensor on the timing light?
Oh and WF?
Thats crazy. Maybe its the wrong points? This makes me brain hurt, if it was my bike I would probably flip out.
youre doing it wrong.
yea dog you're doing it wrong, is your point gap changing? try setting timing by messing with the point gap setting to get it to open or close when you want.
