My clutch get stuck every time i want to start my ciao.
Soooo fix your clutch that would be the logical solution.
Have Keith Bright build you a Bright Special for it.
(edited)
Back when I had a Ciao (1986 or 7-ish) I had to muddle thru the diagnostics on instinct.
I did find the cause of most of the problems.
It was stamped-printed : Made in Italy.
^ he's probably got one he'd sell you for a whole lot of monies
took the clutch apart and it's ok i believe it going to be the flywheel
hit it with a hammer
Could be your bearings are shot in your motor??
the bearings are new but i take the engine apart
How is your clutch "sticking"? The pads or is the motor not turning over?
