Local store for seals
Is there any local stores that would sell seals for an A3? I live in MI. I need two 17 x 35 x 7 seals.
Re: Local store for seals
Look in the yellow pages for your locality. Search for bearings. Any good bearing shop will be able to get that seal for you.
Yep - oil seals for all bikes are available locally at an industrial supply shop. Also check on line, might not be less expensive to order then the local shop but if the shop does not have the size in stock it might take longer then a online order.
The zoo
