peugeot rebuild?
Adrien Pearson /
When i take off my fly wheel to replace my bearings, will i need to reset the timing on my peugeot 103? or is there a key way for the fly wheel? thanks
Re: peugeot rebuild?
No key. You will need to reset it, BUT if you put a little mark on your clutch bell and ramp plate and then another on the flywheel and the case, you should be able to, when putting it back together, make sure that all the lines are lined up and it should be right back where it was.
Adrien Pearson /
thanks
