Motobecane Type 40V
"I go a hold of this Moped and was wondering where I can get info on it. Like if it was a good unit, where to get parts, ect."
Re: Motobecane Type 40V
"what parts do you need?<p><p>: I go a hold of this Moped and was wondering where I can get info on it. Like if it was a good unit, where to get parts, ect.<p>"
": what parts do you need?<p><br>: : I go a hold of this Moped and was wondering where I can get info on it. Like if it was a good unit, where to get parts, ect.<p>"
": what parts do you need?<p><br>: : I go a hold of this Moped and was wondering where I can get info on it. Like if it was a good unit, where to get parts, ect.<p><br>: : I need all four turn signals. The bike was laid down and smashed all up. Also is there an adapter for the valve stem on the tires. I had one hell of a time getting air to them. I had to use an air blow gun and make a seal with my fingers. Also what is the fuel to oil ratio for this engine?"
"i don't think that came standard with turn signals... it takes a 25:1 gas/oil mixture...<br>i find about 3 ounces per gallon work great in my motobecane which has the same engine... when the were produced, they recommended 4 ounces, but the oil quality "
James Burkart /
"<center><img src=""http://www.interlog.com/~paltron/tmc/mop1.jpg""></center><p>You can find parts for your motobecane at www.interlog.com/~paltron/tmc/General_store/general_store.html (Toronto Moped Centre) They have everything you could need.<p>: i don't"
