Can I do it with mapp gas? Has that worked? What rods to y'all like?
BRAZING INTAKE!?!?
Re: BRAZING INTAKE!?!?
If your metal is thin enough. You're talking about steel, right? Just a plumbers torch will eventually maybe get it hot enough. Um… I like brazing rod for brazing. And I like black flux and stay silv, cause I steal them from
work.
Sure can, I did it this weekend when I ran out of o2; that brass rod with the white flux coat works good, is cheap and easy to find.
I've been meaning to give this a go with some of that 'alumaweld' stuff from harbor freight, basically like aluminum brazing.
My intake/pipe technique is just Flux core and some Pam...
That's the ticket. Cheap quick n clean.
I never had a brazing setup, but would love to try it sometime.
Oh, and a lot of junk steel bent tubes.
(handlebars, lawn mower handles, drum hardware, sofa bed corpses)
wonder if that stuff works on the exhaust side.
I have been able to get thin steel red hot with map gas but not puddling like you need to braze. Won't hurt to try it though.
Mike Price Wrote:
> of
Nah, that's why I think it would only be good for intakes/building up cases/etc. It melts at something like 700 or 750 degrees, and headers get way the fuck hotter than that.
You don't puddle the steel to braze. Not at all, if you had to you might as well just weld it with steel oxy rod. Steel glows at something like 1000f and braze melts a little above that. If you can get steel to glow you can easily braze weld. I think once I ran out of acetylene and used a handheld propane torch in a pinch. Works great to make pipes air tight and in a hurry but you can't bbq them to de-carbon them as the braze will likely re-melt. But if that doesn't bother you you can definitely braze weld pipes. I've braze welded many headers and chambers, the egt isn't hot enough towards the walls of the pipe to melt the braze so go for it.
Yo I think this may work:
Show them what you did E.
