I'm restoring a moped and noticed that the throttle grip doesn't spring back to it's starting position. Is there a part of the cable or the handle that engages it that I need to replace? Or should it work properly once I get it running? Or am I just wrong all over and it's supposed to be like that?
Throttle question
Re: Throttle question
What kind of moped? Puchs have a spring in the carb, but none in the throttle itself.
Post a few more times on the other ma forums and it will fix it self.
You posted it on repair already . Try cable lube or other easy stuff like cable binding on something .
