Re: Souping up a Motobecane
Ron Brown /
Measure the carbs and intakes so you can use the largest. The curved vs straight is most likely due to bodywork fitting so you may be limited.
As before, jet without an air filter, then using what you have or can make, set up an air box/cleaner which flows well enough not to screw it up.
Ron
  Souping up a MotobecaneTopic by: mnpd mnpd 04/03/02 03:59AM
  Re: Souping up a MotobecaneRe: Casey B Casey B 04/03/02 10:21AM
  Re: Souping up a MotobecaneRe: Ron Brown Ron Brown 04/03/02 11:50AM
  Re: Souping up a MotobecaneRe: mnpd mnpd 04/04/02 03:07AM
  Re: Souping up a MotobecaneRe: Ron Brown Ron Brown 04/04/02 11:28AM
  Re: Souping up a MotobecaneRe: Simon King Simon King 04/03/02 03:26PM
  Re: Souping up a MotobecaneRe: mnpd mnpd 04/04/02 12:39PM
  We've had it now!Re: don-ohio don-ohio 04/04/02 12:46PM
  Re: We've had it now!Re: Casey B Casey B 04/05/02 12:29AM
  Re: Souping up a MotobecaneRe: John Custodio John Custodio 04/05/02 12:17AM
  Re: Souping up a MotobecaneRe: mnpd mnpd 04/08/02 04:58AM
  Re: Souping up a MotobecaneRe: John Custodio John Custodio 04/08/02 10:25PM
