How do you put a new spark plug wire end on?
joseph parker /
Hey guys, first post. I purchased an NGK spark plug wire end from 1977 and need help attaching it to the wire.
The original one is all cracked, so I assumed it "screwed" onto the wire.
I have no idea how to take the original one off other than to cut it and then crimp on a new end and somehow feed the NGK end over it?
This is the piece that I purchased. CLICK HERE Any help is appreciated.
Re: How do you put a new spark plug wire end on?
You dont mention what brand moped but on most mopeds it just unscrews off the wire. On tomos a35 models, you loosen it with a screwdriver and it'll slide off.
What's a "spark plug" and why would it wear boots?
joseph parker /
gotcha. its a tomos. ill go give it a try. thanks ahead of time.
Arugula!!!
carl jepsen /
nope, more like FLORIDA
joseph parker /
Never dealt with changing just a cap/boot.
Usually do plugs & new wires that already have the ends crimped on.
Unscrewed just fine.
Thanks guys, and you are wrong about FLORIDA.... I would never actually tell my location.
Look up inside the cap where it would connect to the spark plug. You'll see a brass bit with a slot in it, unscrew that and it'll come off.
DAM Kevin Boyd /
