Puch Magnum II Higher Speed
Hi Mopeders,
I have a 1980 Puch Magnum II that runs great. However, it can only hit 23-25 depending on wind. I was wondering what I could do to get it up to 35 or so, to be able to keep up on the roads around my house. I've been searching and have found stuff about taking out the head gasket, and replacing the stock exhaust. Could someone help me with this? Thanks.
Re: Puch Magnum II Higher Speed
--> Jason Kluczyk Presents: Jason Kluczyk /
get a pipe...upjet, buy a cylinder kit
^ yeah boy.
Overpriced Parts /
It should do 29-32 mph stock so you got either a 1.5hp or yours is not tuned correctly/ missing air box, not timed, clogged exhaust
Alright, that's what I've heard most people say. What and where should I get the parts? I don't want to spend too much money on this project, so is there anything I could do to it for really cheap?
Michael Thomas /
Or worse, the dreaded 1.0 hp and the internal trans gears are different.
What does it say on the side sticka?
It was manufactured on 3/80 and the VIN # is: 1607449. If that means anything
Overpriced Parts /
Well for 59.00 you can get a treats 50cc kit and for around 60.00 you can get a boss pipe or a jammy for 54.00 .
That with a few jets (10.00)to upjet and a metal mesh filter (14.00) will get you low 40s mph
I'm totally new to this, so what sites or stores would you recommend for buying these? And how do you upjet a moped?
Overpriced Parts /
Treatland and 1977 mopeds,
When you let more air in a engine you got to get bigger jets to richen the mix
So if you got a 64# jet in your carb get #66-68 jets for the kit and pipe will make more air flow
Wolf Wizard /
www.treatland.tv or 1977mopeds.com
So I'm looking at this:
1. 50cc Treat Kit $69.00
2. Jammy Pipe $54.00
3. And what do I need for jets and filters? If someone wanted to link me. I'm using treatland.
Should I get individual parts? Or this kit:
50cc Jammy Kit Party Supreme
Oooooor this kit? It's cheaper...:
50cc Budget Speed Kit
Overpriced Parts /
6 of one, 1/2 dozen of the other .
You will still need to learn timing and jetting
So search wiki
