what year
Larry Williams /
How do you know what year my motobecace 50 is and what year the motor is? I have a bad bog when I stop and the take off, not sure if it's from comeing up the hill and leveling off or stopping and starting. seams like plenty of power going up hill and once I let the rpm come back up?
Any Ideas?
Larry
Re: what year
SkUG SkUGosarus /
fresh fuel? fuel mixed correctly? cleaned your carb/exhaust, checked your timing?
Re: what year
Larry Williams /
sky OP
All fuel related, carb, filter,lines, are good timing needs ck. but I think I need to know the year?
Re: what year
þλ†Я¡¢k §¡§ΩИ /
Vin plate is on your head tube where the forks meet the frame.
Bogging off line..4stroking/ running rich. Carbon build in your exhaust port. Bad float. Flooding carb. Idle off. Dirty air filter. Timing off. Too humid out.
Re: what year
Larry Williams /
sky OP
thanks I found the I D plate but it has a different motor in it and not sure what year it is I have checked every thing but the timing, it acts more like fuel starvation than to rich and being in New Mexico humidy probably not it.
Thanks
Re: what year
Check the date code on the carburetor, that should date the motor fairly close.
Re: what year
It is 2012... Duh.... Ha ha :p
