Re: Fishing Pole Rack/Holder
Rich (OFMC) /
Go to bass pro or any boat store they make rod holders that you can mount on your wall in the garage. They are heavy duty and the one I got holds 4 poles. Then go smoke a bowl and stare at your moped until you come up with a way to mount it. I'm thinkin drill 2 holes on the side of the bike run a bolt through the rod holder then through a 2inch metal spacer and then a nut. It should stick out enough to clear your seat. You follow me?
