...And most your bikes are not mopeds here where I live :-)
The law says that the moped can run only 50 km/h ,may have two gears and be 50 cm3 or below. So i'm actually going faster than I should but that may be because I only weigh 45 kg :)
BTW I almost forgot...it's not a moped if you start looking at it really carefully. It's a mokick. Not a big difference but still...
And the first gear replaces what you guys use as pedals when climbing a steep hill =D. First gear really has power. But the thing is that your variator transmission mopeds may be faster because no speed limit on mopeds and bigger "reach" of the variator than the "reach" of two gears.
