drive chain for moby
Bought a chain from treats "415" to be able to have one prepared for my 48 tooth sprocket but, keep the original for the stock 11/54--problem is once it hits the master link it pops as it passes the front sprocket--doesn't come loose no prob on the original though--what gives?
Re: drive chain for moby
The front sprocket will have two rubber buffers on each side of the sprocket. If you remove those rubber rings it will sit down on the front sprocket.
So simple yet so annoying if ya don't know--thanks Jesse
