Re: Need Help on Idling & Spark Plug Fouling P
Dan /
"I would check your points out. I was having the same problems, and adjusting the points fixed it.<p><p>: I just put a used carb on my 1977 Motobecane. It starts fine, but afetr running it for a few minutes, the bike stalls out. When I pull the spark plug out, it's covered with a dry back powdery substance. After I clean the plug up, it starts up fine again and than the same thing happens all over. Unless I keep gunning the throttle, the bike will not run at idle on it's own. Any suggestions? I have no idea when the points and condensor were last changed and was wondering if this could be a factor. <p>"
