Tomos Snail Cams Axle Adjusment Fix
Some of you might have had the same problem as I with the snail cams not wanting to stay put. Having to use a vice grip to stop one side and maybe hitting one with a mallot to adjust.
I ordered a set of axle adjusters off ebay
http://www.ebay.com/itm/CHAIN-ADJUSTERS-NOS-Speedway-Vintage-Mini-Bike-/120789776120
and after playing with both installed decided to just use one on the chain side. Leaving a snail cam on the right side of the bike.
100% easier! No slippage of either side. I had a sleeve I cut down and used the second nut from the second adjuster as a lock nut. (edited)
Re: Tomos Snail Cams Axle Adjusment Fix
Dick Johnson /
Thanks for the tip. I ordered a set for my Tomos Revival. Looks like a great item at a fraction of other adjusters on the market.
They claimed there were only six available when I ordered. Any of you thinking of the item had better check it out now.
yup those things never stay put. why just one?
They're much cheaper if you get them from treatland btw. Saves you the trouble of worrying about limited quantities too.
I liked using one cam just to help keep it in place. But since writing the above and taking a ride, I wanted to adjust it once more and the damn snail still wanted to move. So I put both ebay adjusters on to test. Haven't ridden it yet.
Just as an obvious note I shortened the adjusters. And you might need a sleeve of some kind to push the nut back as the threads are pretty much dead on to the end of the swing arm.
And I couldn't find an extra nut that fit the adjusters- not sure threading size.
Best,
Xeta (edited)
On treats the ones that come with the back ends look cheaper and aren't solid all the way around. The ones that are don't come with the back pieces so IDK. All good either way.
this is like common sense guys. come on really?
only works on wide robot swingarms too
magnum adjusters, not new...
Maybe not but I haven't found any info on adjusters for Revivals which I own. Just people having trouble with snail cams.
tighten your nuts and you wont have such issues
For those interested finally I'll say I tried using both adjusters and it was just easier using one adjuster and one snail cam as I originally posted with the eyelet adjuster on the chain side. Still much improvement over using both cams.
Best,
Xeta
Dick Johnson /
Thanks for the update. I'll follow your suggestion when I receive the part.
I, too, have found the snails a pain in the arse. I use needle-nose lock pliers when adjusting and never get it right on the first try. All this while resting on my elbows, laying prone alongside my bike in the driveway.
BTW, I have learned to prop up my back wheel off the ground with an 11 x 2 PVC pipe. It works so well I carry one on the Revival, as a case for my folding air pump.
You'd think after so many years Tomos has been in business it wouldn't be such a 'pain' to do!
