coil help?
getting power to coil but nothing coming out
coil tested good
any ideas?
Re: coil help?
Patrick Keaton /
I guess you are refering to the high tension coil. If so, use a spark plug that is known to be good. The spark plug cap could be bad. Run the spark plug wire straight to the top of the spark plug, and see if that helps.
Re: coil help?
If all that is OK but it won't spark put a new condensor inside or externally
Re: coil help?
thank you i will be getting a new condensor shortly to try that out
