new tomos 50cc a35 high compression head. Need to break in?
Chris Davis /
searched. Didn't see one about getting a new head. Do I need to break it in? Kind've like a kit or is that only if it involves the piston and cylinder?
oh and its a 50cc puch head from treatland. And I do have a gasket to use
Thanks.
Re: new tomos 50cc a35 high compression head. Need to break in?
Nope, no break-in on the head, that's just for cylinder/piston/rings. Youre good to go!
Chris Davis /
another quick question. Should I switch back to my stock exhaust? I have read that expansion chambers may cause problems with hi compression heads. I have the technigas next.
thanks
The only problems you will have with a hi comp head is higher cylinder temps. But if you are at stock 50cc, youre probably fine (aka, dont put the stock pipe back on unless you want to take away all the gains the pipe gives you).
Chris Davis /
ok thanks again
