Re: new tomos 50cc a35 high compression head. Need to break in?
Josh Cranston /
The only problems you will have with a hi comp head is higher cylinder temps. But if you are at stock 50cc, youre probably fine (aka, dont put the stock pipe back on unless you want to take away all the gains the pipe gives you).
