i have an 87 targa i have been fooling with for way to long. i got the bike and the wiring was a mess ( rigged up) i bought the bike knowing it had no spark and thought putting the wiring back would most likely solve the problem. so i have it all back like it should be this is all the things that are going on now.
-both wires from mag make power
-rear light is in and lights up when being kicked
-power wire going into coil is getting power
-spark plug side not getting any juice all the time (but on occasion it will spark)
-primary coil tested good 1.3 ohms
-secondary coil tested good 83k ohms
-kill switch is good
i can test anything else you think might be the problem. It sounds like a ground issue to me but i could not find a ground that seemed bad. anyways i would appreciate any ideas and would be more then happy to test them out
