good luck to you man. I don't know tomos, but with all the other bikes I have hotwired, you can literally pull the connector off which is plugged into your ignition (key lock deal) This will possibly disable your starter. so kick start only. I have seen in the past where the lights are routed through there as well. if that is the case you will have to rewire the lights. (and if there is a battery, install an aux swicth so you can turn em off when you stop.) A locksmith (or a crafty have-not) can get you into the seat. then jam the latch so it won't close up on you.
