Help.. stolen key. New ignition?
Shawn Martin /
I lost my key to a 05 Streetmate. Can I get a new ignition key switch and key or connect certain wires to have a constant ON with the ignition?
Re: Help.. stolen key. New ignition?
Patrick Keaton /
You should have the option of a new ignition key switch and key from Tomos and/or one of there dealers. You should also have the option of connecting and/or remove certain wires to have constant ON with the ignition. Here is the wire diagram with the switch in the right side corner. http://www.mopedarmy.com/mediawiki/images/6/69/Tomos-wiring-2005-07-streetmate-100dpi.jpg
Shawn Martin /
I hope I can get a key...otherwise how would I unlock the seat to put gas in?
That wiring diagram: bird's nest
streetmates are very easy to hotwire, but as you said, that doesnt put gas in the tank thats locked under the seat.
Shawn Martin /
How do you hotwire it? Is there a way to break the lock and just ride with an unlocked seat until I buy another lock set later on? They want $150. And one dealer said I couldn't just buy a new key. (edited)
good news! you already have a spare key, it's called a screwdriver.
Mopeds have keys!?!?
What is the world coming to?
good luck to you man. I don't know tomos, but with all the other bikes I have hotwired, you can literally pull the connector off which is plugged into your ignition (key lock deal) This will possibly disable your starter. so kick start only. I have seen in the past where the lights are routed through there as well. if that is the case you will have to rewire the lights. (and if there is a battery, install an aux swicth so you can turn em off when you stop.) A locksmith (or a crafty have-not) can get you into the seat. then jam the latch so it won't close up on you.
Patrick Keaton /
Call every locksmith in your yellow pages, and find out how much they charge to make a key. If they have, or can get , a key blank, it might be as little as $10, if you demand a little off there price they give you. All they do is stick a blank key in the lock, and turn the key, and remove the key. Then they look for marks on the key, and they file the area away from where the marks are made.
Darrell Gabbard /
sometimes there are a couple of numbers that are located by the key switch that a locksmith uses to make a new key
Stolen key?
Shawn Martin /
Well to reply to multiple posts...
Screwdriver didn't work.
I have a bike/lock shop looking at it today. $30 if he can do it.
And either stolen key or some kids thinking it would be funny to remove it when I went into the store. And yes... should have remembered to take it out.
SkUG SkUGosarus /
I'd personally change the lock, if someone has your key... they have your moped when you're not looking!
Patrick Keaton /
$30 is too much. Did you call all the locksmiths in the yellow pages ? You should find a locksmith that will do it for $15, then talk the locksmith down to $10.
Not sure if Tomos does key codes or not.
I had to have a key cut for a scooter not long ago.
I pulled the ignition and took it in to get an impression made.
Cost me $40 and I was happy to pay it.
If you didn't have to unlock it to get at the gas I would just say hotwire, but yeah just bite the bullet and pay some dude to do it.
Darrell Gabbard /
a long shot would be if you contact Tomos usa and see if thet have the key code on hand and send you out a key
Patrick Keaton /
Do you have the key code that was on the key ? Is there a key code on any of the locks ?
Shawn Martin /
Check the attachment. If I connect the pink and yellow wire..would that act as if the key was in the on position? Anything else I would have to rewire? The ignition is unplugged and sent off to a locksmith. Right now the bike runs and then headlight works but the brake light and turnsignals do not. I was hoping connecting the pink and yellow would fix that. I was able to get to the gas tank... so all I really need is the brake light/turn signals to work and I wouldnt need a key for anything.
Shawn Martin /
Tried to post this before and it didn't show up. Sorry if this becomes a duplicate...but:
Check the attachment. If I connect the pink and yellow wire (where the arrows are pointing)..would that act as if the key was in the on position? Anything else I would have to rewire? The ignition is unplugged and has been sent off to a locksmith. Right now the bike runs and the headlight works but the brake light and turnsignals do not while the ignition is unplugged.. I was hoping that connecting the pink and yellow would fix that but I haven't tried it yet and I don't want to fry anything. I was able to get to the gas tank... so all I really need is the brake light/turn signals to work and I wouldnt need a key for anything. (edited)
Patrick Keaton /
That should be what needs to be done, but that might not be the only thing needed. You need to get a small solid wire, and remove the insulation on both ends, and put one end in each of those connectors. If there is a battery on there, you might need to remove the wire when not in use, or put a switch in between the wire.
Shawn Martin /
So you think that will get the turn signals and brake light to work? If thats the case, I think I'll just make a toggle switch between the two.
Brad William /
Most simple locks have pins or cams inside that are very easy to remove (that is, once you get to the mechanism, which requires you to unlock it in the first place, which does not help you much I guess).
But it's surprisingly easy to remove tumbler pins or simple cams in locks so that in the future all you need to unlock them is any key or even a key-like piece of metal. My old Honda Civic was like this. I got so disgusted with myself for locking the keys in the car... and then later that day locking the fucking hide-a-key in the car.... that I just pulled off the door liner and attacked the lock. On mine there was a simple stamped spring-steel cir-clip holding the tumbler pin in. I pried off the cir-clip, removed the little loose tumbler pins with tweezers, and replaced the clip.
It remained like that for ten years. I loved it. Once in Savanna GA I came back to my car to find the driver's side window smashed in and my stereo pulled halfway out of the dashboard. The guy must have gotten interrupted. I thought the episode was pretty funny because it would have been a hell of a lot easier if he'd just opened the door with his car key. But what possible reason would he have for guessing that his key would work? Exactly.
Same logic works for ignition as well. Just hardwire it and find the most obscure spot on the ped possible for a toggle kill switch (not momentary).
Anyone trying to start your ride to steal it (unless they were watching you really closely when parking it) is gonna be in too big of a hurry to find a hidden kill switch. And you'll never loose your "key". Heck, I could hotwire your ped a LOT faster than I could find your hidden kill switch. Hot wiring only takes a safety pin shoved through the right two wires. (edited)
Patrick Keaton /
This is what the wire diagram tells me is a part ,and could be all ,needed to solve the problem. There are at least 2 other wires that may play a part, but starting with the wire you listed, looks to be a good starting point. I have never worked on that model, so this is not hands on information.
