Re: batavus engine swap question
david koch /
If you are going to swap engines a two speed is the way to go. Here is what i did with a tomos engine. The swap only takes a pair of brackets and you only need to drill the upper right hole. All the other parts are stock tomos parts. Stock a3 bottom end with a35 top end and intake with a 1/8'' cyl. spacer to bring the port timing to 162 ex. 120 transfer and a pipe. Pulls to 9300 RPM with 28/22 gearing over 45MPH. I can make you a pair of brackets for the engine and a ex. bracket. here are some pics.
