Re: 1975 batavus couples questions
Joe Conte /
Rust on Chrome:
Spray on some PB Blaster or other penetrating oil
Use fine steel wool to get rid of the rust
Wash off the oil, dry
Get some Ospho from the hardware store. Wet a paper towel with it and go over the item. Let it sit overnight. This will seal the bare spots and prevent rust from returning.
Even if you intend to paint the rust areas on the muffler, the Ospho is a must before priming and painting.
Filling up at the gas station:
Even with the reserve amount in the tank, a Batavus should be able to take a gallon of gas. Carry a measured amount of oil for one gallon (actually 2.6 ounces, which is almost exactly 1/3 cup). It should fit under the seat, no problem. Put in the oil first, then exactly one gallon of gas. The gas flowing in mixes it just fine. You can top off from your premix can when you get home.
The "gas first" is OK if you don't know how much gas it's going to take, so you have to do the math for the right ratio afterwards. Putting in exactly one gallon eliminates that problem.
  1975 batavus couples questionsTopic by: Brad Eadie Brad Eadie 06/19/12 03:12AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 08:05AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/19/12 09:45AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 09:49AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 09:50AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/19/12 09:56AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 09:58AM
  Re: 1975 batavus couples questionsRe: Patrick Keaton Patrick Keaton 06/19/12 11:05AM
  Re: 1975 batavus couples questionsRe: Susie Two Stroke Susie Two Stroke 06/19/12 01:23PM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 10:50PM
  Re: 1975 batavus couples questionsRe: - Summerai - Drew - Summerai - Drew 06/19/12 01:05PM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/20/12 12:24AM
  Re: 1975 batavus couples questionsRe: Patrick Keaton Patrick Keaton 06/20/12 12:54AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/20/12 02:50AM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/20/12 03:11AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/20/12 08:21AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/20/12 08:27AM
  Re: 1975 batavus couples questionsRe: Lou C Lou C 06/20/12 09:26AM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/20/12 10:42AM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/20/12 10:56AM
  Re: 1975 batavus couples questionsRe: Hugh Janus Hugh Janus 06/20/12 10:57AM
  Re: 1975 batavus couples questionsRe: kevin a kevin a 06/22/12 02:09AM
  It is still a mysteryRe: fallout Survivor fallout Survivor 06/22/12 07:03AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/22/12 07:01AM
  Re: 1975 batavus couples questionsRe: Graham Motzing Graham Motzing 06/22/12 11:51AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/23/12 05:51AM
  Re: 1975 batavus couples questionsRe: Joe Conte Joe Conte 06/22/12 12:08PM
  Re: 1975 batavus couples questionsRe: Aron Chaudiere Aron Chaudiere 06/23/12 03:00AM
  Re: 1975 batavus couples questionsRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 06/23/12 03:09AM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/23/12 03:17AM
  Re: 1975 batavus couples questionsRe: Patrick Keaton Patrick Keaton 06/23/12 02:03PM
