Re: 1975 batavus couples questions
Susie Two Stroke /
I'm learning all about fouling plugs but they are easy to clean with carb cleaner! As for your mix if you are using synthetic you may want to use more like 50 mililiters per gal of gas if you use semi synthetic 75 mililiters. The richer you run the more likely you are to foul your plug the leaner you run the more likely you are to seize your bike/engine which is way worse (all of this is a learning process which is unique to each bike and where you live/climate/terrain/etc....)
As for getting lite rust off of chrome, use fine steel wool and oil baby oil or even wd4 will work don't use too much cause it will never come off.
  1975 batavus couples questionsTopic by: Brad Eadie Brad Eadie 06/19/12 03:12AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 08:05AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/19/12 09:45AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 09:49AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 09:50AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/19/12 09:56AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 09:58AM
  Re: 1975 batavus couples questionsRe: Patrick Keaton Patrick Keaton 06/19/12 11:05AM
  Re: 1975 batavus couples questionsRe: Susie Two Stroke Susie Two Stroke 06/19/12 01:23PM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/19/12 10:50PM
  Re: 1975 batavus couples questionsRe: - Summerai - Drew - Summerai - Drew 06/19/12 01:05PM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/20/12 12:24AM
  Re: 1975 batavus couples questionsRe: Patrick Keaton Patrick Keaton 06/20/12 12:54AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/20/12 02:50AM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/20/12 03:11AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/20/12 08:21AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/20/12 08:27AM
  Re: 1975 batavus couples questionsRe: Lou C Lou C 06/20/12 09:26AM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/20/12 10:42AM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/20/12 10:56AM
  Re: 1975 batavus couples questionsRe: Hugh Janus Hugh Janus 06/20/12 10:57AM
  Re: 1975 batavus couples questionsRe: kevin a kevin a 06/22/12 02:09AM
  It is still a mysteryRe: fallout Survivor fallout Survivor 06/22/12 07:03AM
  Re: 1975 batavus couples questionsRe: fallout Survivor fallout Survivor 06/22/12 07:01AM
  Re: 1975 batavus couples questionsRe: Graham Motzing Graham Motzing 06/22/12 11:51AM
  Re: 1975 batavus couples questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/23/12 05:51AM
  Re: 1975 batavus couples questionsRe: Joe Conte Joe Conte 06/22/12 12:08PM
  Re: 1975 batavus couples questionsRe: Aron Chaudiere Aron Chaudiere 06/23/12 03:00AM
  Re: 1975 batavus couples questionsRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 06/23/12 03:09AM
  Re: 1975 batavus couples questionsRe: Brad Eadie Brad Eadie 06/23/12 03:17AM
  Re: 1975 batavus couples questionsRe: Patrick Keaton Patrick Keaton 06/23/12 02:03PM
