Re: HELP? Does anyone know what model1978
Patrick Keaton /
Does the VIN numbers on the VIN plate match the numbers on frame area under the seat and the numbers on the engine where the wirescome off the engine ? Maxi Sport had a sticker around the rear fender with Maxi Sport on it. Since it does not have that sticker, it makes me think it is a 1980 Maxi Luxe, but if the frame numbers matches the VIN plate numbers, that will not be right , since you stated the VIN plate is labled a 1978.Silver and the engine say 1980, everything else say 1978. The air filter has parts that go with it to make it a 2 HP, but those parts do not come with it that often when you get it, so basicaly there is only one air filter for it. If you get side covers, try not to get the one with the cut out spot for the coil, since that is for the 2 speed, but it will work, if you do get it.If you tell what parts you need , then you can be told what to get.
