Re: Noob... Needs help (puch maxi)
Pizza the Hutt /
There is probably nothing wrong with your ped or it's clutch. it's just a stock, (sounds like) 1.5hp, e50. a destroyer of hills it is not. plus NH hills are not small (I gre up in MA, i know what you're facing). Just get a bumper sticker that says "this moped can not climb mt. washington" and save up for a kit.
Upjetting alone will not really give you the better torque that you're lookin for. jetting a little higher can make you slightly quicker off the line but it's not going to be significant on a 30 degree incline. go back to stock and save your plugs, it's actually probably why you're bogging out.
Also, dont mess with the clutch or timing. you could try derestricing the pipe for some short term help but it's all a drop in the bucket. go with the whole kit setup. when picking your setup, tho, think about a circuit pipe. It will keep your power band in the lower rpm range and help you out on those hills.
or buy a hobbit
