Is this M1 pre/post 1985?
Andrew “No-No” Strother /
Re: Is this M1 pre/post 1985?
measure the bore of the cases!
Not mine to measure - I'm in the process of purchasing it.
Tri-ped Dave O.D.B. /
Just a guess without the ability to measure, but logic says that the "new valve engine" sticker would indicate early version, since by '85 there was nothing new about the reed valve model as it had been around for years
You're going to want to open the transfers anyways since it sounds like you plan to kit. Will just take some extra time to work the skirt clearance if in fact you need to. Buy it before someone else does I am considering this also.
me too hurry!
Pre post erous
Tizz mine, so fine - spanks broods.
