i got 16mm carb
Trent Stakelin /
what jett should i use
there is a 75 right now i just want right jet.
my bike is tomos targa lx
with bi turbo
16mm carb
Re: i got 16mm carb
i got a mopad
and it's got tires and
18-20 zipties on it
should I upjets or downjetts
K thx by
Re: i got 16mm carb
Probably Fred /
Experiment with 60s, 70s and maybe 80s
Please post what works on the spread sheet
Re: i got 16mm carb
62
Re: i got 16mm carb
wiki spreadsheet.
Re: i got 16mm carb
im new and can be pretty vague but damn.
Re: i got 16mm carb
Tri-ped Dave O.D.B. /
Any chart is just experience of others experiments
EVERY single moped breathes differently dependent on multiple factors, and you MUST check the plug for that nice coffee with cream color or risk running it too lean and blowing it up since the lubrication is mixed with the fuel.
That being said, the chart is just a starting point, you may get lucky, but you have to check. Begin with the jet listed for your particular setup, then run it for 5 minutes at speed, dont let it idle, and check the plug color then adjust accordingly. If too white upjet, if too dark, downjet. there is NO substitute for this procedure
