Re: 1975 Hercules p1 wiring
♣Slew Foot♣ /
Easy peasy
Yellow is power out.
Black is ground.
Yellow into wiring block green yellow and grey out.
to brake .
headlight horn .
Running light .
The black goes to another wire block for grounds or strap the motor to frame (rubber mounts) and run ground to frame.
The problemo will be the replacement bulbs. 3w brake 2w running light 18w head all 6v.
It depends on your magneto.
It says what it puts out.
Multi coil Pug Cdi replacement.
Or figure an led workaround .
Old bike tire generator. charger for tail.
