bet you have never seen this Hobbit / Camino subframe before...
Sneak peak. Only have a few hours running time but so far so good.
designed by fellow swoops Matt Turner and Bobby Costello. I myself get to be the Guinea pig.
Re: bet you have never seen this Hobbit / Camino subframe before...
adjustable Shocks/Foot-peg mounts?! word word right right.
I assume it is stiff? Looks pretty simple so= good.
Gromosaurus Rex - Brad Pitt /
Been following this concept on FB. Nice work. If u need a fatter Guinea pig let me know.
blk blk derrick has an adjustable mono shock pinto.. had the subframe all customized/welded by some super rad local bicycle builder.. shit was sooooo smooth
Emil Kniemel /
that pinto is hot.
can you still use the side covers on the hobbit?
@RACHID, comparing the flex to the stock stamped camino subframe this one's for def noticeably stiffer.
and kevin. paint!
Side covers could be used if holes were drilled
. I ditched mine
Yeah Will, paint is on the list. I just don't have the money yet. This damn thing already has me in the hole over a grand. Why, why, why! Do I do this!? Lol
Well done. Looks beefcake as heck.
