Did anyone here have any problems with the Tomos Signal Light Switch for the Tomos Spirit, Targa or Targa LX?
My signal lights worked fine at first but now only work when I wiggle the
switch and then not always.
Is this a common problem or is my signal light switch defective?
Is there a generic signal light switch I can replace it with?
Is there any way I can get the signal lights to flash faster?
The Tomos Spirit, Targa or Targa LX does not have a battery so will
an electronic flasher relay work with it (I was told that you can't replace the bulbs in these models with LED replacements because they don't have a battery and may be the electronic relay may also not work in these models).
