Minerelli Scooter Cylinder Stud Spacing?
I have a semi off topic bike with what appears to be little parts support, I found the stroke to be real close to Minerelli scooters, but does anyone happen to know what the cylinder stud spacing is? If its close, I need to find a junk cylinder to mess with..
Re: Minerelli Scooter Cylinder Stud Spacing?
close to what?
Totally normal JBOT /
Vertical minarelli is the same as puch
Horizontal minarelli is the same as hobbits (or super super close)
I'm looking for close to 46mm spacing. I have a Hobbit head, and a Puch head, ill check both, but I believe it is the horizintal Minnereli that has a stroke of 38mm?
Stud spacing is 48mm. Doable on a 46mm id the cylinder has large holes or drill em
Awesome. Anyone have a junk cylinder they want to give up so I can see if this will work?
Hit up a sccoter shop for a blown unit
Sadly, we don't have any scooter shops. Just a dirtbike store that sells Chinese scooters. Biggest city in Ks is 40 minutes away, and even they don't have a scooter shop. I gotta rely on Ma. I'll put up an ad in a bit.
