Legally motorized bicycle = MOPED
fallout Survivor /
Per one state statute:
§60-637
A moped is defined as a bicycle with fully operative pedals for propulsion by human power, an automatic transmission and a motor not exceeding 50 cc that produces no more than two brake horsepower at a maximum design speed of no more than 30 miles per hour.
Mopeds are exempt from titling and registration. They can be operated on public roads as long as the operator complies with the laws regarding mopeds and the pedals are not removed .
While mopeds are exempt from titling and registering, if at any time the pedals are removed the vehicle becomes an off-road vehicle restricted to operation on private property unless it meets the minimum requirements of a motorcycle . If it meets the minimum motorcycle requirements then must be titled and registered for legal operation on public roads.
  Do you consider these as MOPEDS?Topic by: Jason Crawley Jason Crawley 06/08/12 10:38PM
  Re: Do you consider these as MOPEDS?Re: ugp * 🧪 ugp * 🧪 06/08/12 10:44PM
  Re: Do you consider these as MOPEDS?Re: *sha 1412* *sha 1412* 06/08/12 10:50PM
  Re: Do you consider these as MOPEDS?Re: bill Stoudt bill Stoudt 06/08/12 10:58PM
  Re: Do you consider these as MOPEDS?Re: David Daughters David Daughters 06/08/12 11:03PM
  Re: Do you consider these as MOPEDS?Re: J Blank J Blank 06/08/12 11:14PM
  Re: Do you consider these as MOPEDS?Re: M-Tenn Aaron M-Tenn Aaron 06/08/12 11:16PM
  Re: Do you consider these as MOPEDS?Re: Jumper K. Balls Jumper K. Balls 06/08/12 11:29PM
  Re: Do you consider these as MOPEDS?Re: Nikolas Sanow Nikolas Sanow 06/09/12 12:58AM
  Re: Do you consider these as MOPEDS?Re: Salsa Salsa Salsa Salsa 06/08/12 11:38PM
  Re: Do you consider these as MOPEDS?Re: Edward Richardson Edward Richardson 06/09/12 12:01AM
  Re: Do you consider these as MOPEDS?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/09/12 04:55AM
  Legally motorized bicycle = MOPEDRe: fallout Survivor fallout Survivor 06/09/12 05:22AM
  Re: Legally motorized bicycle = MOPEDRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/09/12 12:36PM
  Re: Legally motorized bicycle = MOPEDRe: Road Rash Dave Road Rash Dave 06/09/12 01:36PM
  Re: Do you consider these as MOPEDS?Re: M-Tenn Aaron M-Tenn Aaron 06/09/12 08:50AM
  Re: Do you consider these as MOPEDS?Re: King Drunky JCams King Drunky JCams 06/09/12 09:39AM
  Re: Do you consider these as MOPEDS?Re: fallout Survivor fallout Survivor 06/09/12 11:59AM
  Motor Pedal = Moped .. registration licensing needed in most jurisdictionsRe: Tptwo Tptwotwo Tptwo Tptwotwo 06/09/12 10:18AM
  Re: Motor Pedal = Moped .. registration licensing needed in most jurisdictionsRe: ~ DeeZy ~ DeeZy 06/09/12 11:23AM
  Re: Do you consider these as MOPEDS?Re: Josh Rampulla Josh Rampulla 06/09/12 11:10AM
  Re: Do you consider these as MOPEDS?Re: Flagrant - Flagrant - 06/09/12 12:22PM
  Re: Do you consider these as MOPEDS?Re: Matt Kefer Matt Kefer 06/09/12 12:30PM
  Re: Do you consider these as MOPEDS?Re: Aron Chaudiere Aron Chaudiere 06/09/12 12:32PM
  Re: Do you consider these as MOPEDS?Re: Weak-Ends Tj Weak-Ends Tj 06/09/12 12:34PM
  Re: Do you consider these as MOPEDS?Re: Cosmo nPuch Stillstolen Cosmo nPuch Stillstolen 06/09/12 01:51PM
