Re: Tomos - add an AC regulator b4 rectifier?
Chris Davis /
let me clarify. Like for the head light. I leave harness intact. Get a solid state relay that will do 12dc for the load and be triggered by dc (never seen one that is triggered by ac). Hook a rectifier up to the headlights regular + and - terminal. Then hook that to the the solid state relay trigger. Meanwhile, run a wire from a battery and then you can still keep the harness pretty much intact and not have to mess with new grounds and so on.
I can charge my battery @ work and its only 5 miles away.
get a larger 20amp version for the headlight, a smaller 2 amp should world for the rest.
  Tomos - add an AC regulator b4 rectifier?Topic by: Chris Davis Chris Davis 06/06/12 07:18PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 09:25PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/06/12 10:31PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Weak-Ends Tj Weak-Ends Tj 06/06/12 09:30PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/07/12 02:53AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Steve Mertz Steve Mertz 06/06/12 10:51PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 11:54PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 11:58PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 01:16AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 03:17AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 03:30AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 08:48AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 09:27AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: John Warren IhazJawas John Warren IhazJawas 06/07/12 10:29AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 01:58PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 02:03PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 02:10PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/07/12 07:16PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 07:24PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Goose . Goose . 06/08/12 12:09PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Totally normal JBOT Totally normal JBOT 06/08/12 12:34PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/08/12 09:18PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/08/12 10:15PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Goose . Goose . 06/09/12 01:37AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/09/12 01:57AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Totally normal JBOT Totally normal JBOT 06/09/12 01:55AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/10/12 04:55AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/10/12 05:04AM
